Can I fix/polish my Fluidyne Radiator??
Brian
154
Mar 26, 2002
toledo, Ohio
Alright I bought a used fluidyne Radiator for 250 bux and it works perfect but the top part which is supposed to be all shiney and nice looking has a stain of soem sort on it and a few small scrathes which arent that deep. My question is can I get rid of these scratches and stain by polishing it like having a pro do it, or coudl I do it on my own also. Let me know I want it to look good.
Yup. Anything that is designed for polishing aluminium (count the i's, folks) will do the trick.
Depending on the finish you want and how deep the scratches are, you might start with a fine stainless steel pad and some WD40, then work your way down through some cutting compound and finally to some proper aluminium polish.
Figure that you are trading a bunch of sweat for the cash you'd give to a professional.
Well I will most likely take it to a pro because I wouldnt want to try it and mess it up.
