AlaskanDsm
- 1,124
- 17
- Oct 21, 2007
North Pole,
Alaska
I did a search on here for a little bit and I couldn't find anything that solved my question.
On my car when I go to make a turn in either direction my blinker works just fine. But only the flashers on the front of the car closest to the mesh talon emblem in the center flash. On almost every other car that light flashes and the lights on the corner flash(on the side of the car so a car next to you could see you turning per say)
I don't even know if they are supposed to flash!!
I looked through my haynes and didn't see anything there either. If they are supposed to work then I will get down to making them work...but if not then ok! less to fix!!
