What do i have to cover if i'm going to spray down my engine?
I just dont want my car to not start or something and be stuck in the wash bay, that would suck haha. ill just cover my K&N i guess. My fuse box is covered. Do i have to cover alt / battery?
i usually just put a plastic bag over the filter. you should be good. Although personally I don't like the idea of high pressure washing. I would personally just use some simple green, a brush, sponge, elbow grease and a hose. My engine bay was filthy when I first got it, but i just took about an hour with a brush and now it's squeaky clean.
I say either a flamethrower... Or what Just2asian said.
Cover the filter if its an open element, alternator, perhaps the battery, just don't go crazy spraying anything electrical and you will be fine.
you don't need to cover the filter.. just don't spray directly at it.. won't hurt it to get wet.. the fusebox will also be fine..
The only thing you should worry about covering is the CAS.. they don't like water.. and have some paper towels or compressed air to get any water out of your spark plug wells before starting.. I've pressure washed literally thousands of engines, you'll be fine.
You can't do this with all cleaners, some state to use on a cold engine with engine off
when i detail cars at my dealership, i just use a degreaser w/the power washer...
i always leave the engine on, just because you never know...
always works for me!
degreasers are more likely to damage things when they dry out.. that's why some say not to use it on a hot engine..
You have your own dealership ? I thought when pressure washing the car it was best to turn off car and let it cool down some and then let most of the water dry before starting it back up? :confused:
at the detail shop i work at we just degrease n pressure wash and dont really cover anything but cover ## filter and not blastin the piss outa the distributor is a good idea
no i dont, i am a salesman/detailer...
i used to turn off the car when i would pressure wash them, but my manager told me to keep the car running...
i dunno tho, its always worked for me
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
