Where to get special lugs for Rota Slipstreams
Aaron91RS
148
Nov 10, 2003
St. Louis, Missouri
The bronze lug that matches the bronze rota slipstream. The one that just takes a 3/8 drive to get off and not a socket because it's perfectly round on the outside.
Who sells these?
I got the simlar lugs but in silver to match my wheels at my local tire shop. They weren't too bad, 1.50 a piece with a special locker bolt for one of them each.
Try calling around, and you should be able to find them.
Howie~
You got lugs that are perfectly round on the outside and don't use a hexx socket to get off (because well they are round and it wouldn't work anyway)
locally?
Well, You have the aftermarket rims where regular lugs wont' fit in.
Soooo, you're looking for the smaller lugs that fit directly inside of the socket holes, that erquire a hex key in order to take them otu, correct? Yeah, I got them locally. Most customs shops *if they sell wheels* will have them.
The hex key *It's a little adapter that fits in a hex socket* costs about 10 bux, and a locker key with bolts was an extra 15 dollars all together, w/out the other lugs. a little expensive, but, eh... It works and it looks a lot nicer :D
Howie~
Actually it doesn't even take a key of any kind, Just a 3/8 drive.
No need to find a socket for anything, but I guess what your talking about it close.
