ThumperSS
- 47
- Oct 20, 2002
Hey guys and gals. I'm about to install 2 of the 4 gauges onto my car but am a bit confused on what fuse to use. Heres the deal, instead of wiring the gauges to my cig lighter I plan to use a 30amp relay which is connected to the battery. the relay will be connected to a fuse holding unit which will contain (4) fast acting 4 amp fuses for each of the gauges. (They are autometer ultralites). I have yet to get the 2 other gauges because I dont need them right now. Now i was reading to just add up all the amps and use that number for the fuse which will go before the relay. Now if thats correct I should be using a 16amp fuse but I dont think they make that fuse. Could I use a 20amp fuse instead? I just need some clarification on how to find out what fuses to use. Thanks for your help guys.
