Dismantling Interior
BurnBarfield
146
Oct 23, 2005
Murfreesboro, Tennessee
I've started repaint my interior, but I've run into the problem of how to take some things off.
How do I pull the glove box out?
How do I pull the surrounding of the center vents and rear defrost thing?
How do I pull the surrounding off of the panel to the left of the steering wheel, I think it is for auto mirrors?
The Glove box has two little stops on either side when its completly down, pull those in so you can pull it down all the way, then there is a metal strip with three screws in it.
If you search forums on removing your dash you should be able to find everything you need. Just simply type in Dash Removal
just take a flathead screwdriver to the center vents and the thing to the left of the steering wheel (the cruise control switch) and it should come right off...and follow what he said about the glove compartment.
