97-98-99 Eclipse's...different?
BstOnTheBrain
Oct 18, 2005
Rochester, New York
Im in the search for buying an Eclipse id really like a 98 or 99 but found a decent deal on a 97. Is there any differences between the 97-98-99 Turbo Eclipses (mainly GSX) either on the interior or exterior or mechanical? They all LOOK similar but is there any small differences i dont see?
Well, I don't think so. I know in 97 they changed a few things, but I think they kept them the same till 99.
:dsm:
year of 1999...eclipse came out in black interior colors.....
All three years are the same except in 1999, black leather became an option, and white face gauges were introduced. Nothing else changed.
Keep in mind though with late '96 build dates, there is a problem with the OBDII ecu when reading it for inspection. I have this problem, but am fortunate enough to slip through the cracks.
First off, read EVERYTHING on this site. It has helped me tremendously with my car.
http://members.shaw.ca/costall/1000Q/
Second, what you are looking for is this:
1997
Additional body changes from the 1995/1996 models.
Minor changes to the ECU code.
1998
After many years, Mitsubishi finally issues a recall on the AWD DSM transfer case.
1999
The last year of the 2G car, and of the 4G63/AWD DSM platform.
The last year of the Eagle Talon. Chrysler drops the Eagle marque.
The black interior is the only big difference that I've heard of in 1999 though. I found this under make and model info.
I believe the white face gauges were part of the 10th anniversary OZ package only.
1997
1998
1999
Just thought I'd let you know, the last year of the Eagle Talon is 1998, not 1999.
no,all 99 have the white face gauges and everyone forgot the cd changer only in the 99 which i have no clue how to use :D
misinfo is not funny
not to add to the confusion,but didn't all 99's come with the oz package?I have seen a number of gs eclipse with the sport wing,leather,gsx rims.all were 99.love the black interior on the 99.I'm gonna try and get one of those next.I will sacrifice the AWD for black leather and a 2g body :p .but i won't sacrifice the turbo.can't make the same mistake twice.
OZ package was '99 GS's only, and all of them. They came with 16 inch OZ wheels that looked like the GSX wheels, but were not.
Nobody has mentioned that in 98 they switched to the split thrust bearing 7 bolt. Not that it really matters, but all of the crankwalk junkies might think it does.
Thank you black widow! I was wondering when somebody was going to mention that! I have the sliver faced gauges, Also 98-99 have the black ECU.
Was just going to say thrust washers but seen its finally been mentioned! The wheel bearings are slightly different on the 99, late 98-99 charchol canister is in front rather then at the rear. Minor stuff but worth a mention[DOUBLEPOST=1417706039][/DOUBLEPOST]Cold air when heat is on. Pretty sure thats on every 2g[DOUBLEPOST=1417706083][/DOUBLEPOST]
Don't some years have the weird cool air bypass thing on the center vents?
Could someone tell me if there were ANY changes to the engine mounts and/or transmission mounting locations from 95-99?
Thanks,
  • For sale 1g 1G Turbo Intake Kit
    Used 1G turbo intake kit. Fits on stock intercooler and uses stock BOV. Comes with the MAF and...
    • Badge023
  • For sale 4G63 Used FP 4G63 Turbo Manifold
    Used FP 4G63 Turbo Manifold removed from 1G Talon. Looks okay, needs a cleaning. Did not see any...
    • Badge023
  • For sale 2g Fiberglass Fenders
    2g Fiberglass fenders. Overall good condition. $50 + Shipping/FeesFor faster response Text...
    • 1SlowPOSEclipse
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
