1990 GS-T Bodykit
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
Hey guys,im wondering how my dsm looks with the bodykit on it,does anybody got the bodykit on the 90-91 Eclipse???!! and where i can get it or take a look how does it look on that kind of car :dsm:
i know of like one for the 1ga, any 1gb's will fit but req's custom work to make it fit...you could probably try extremedimensions.com
i have a 91 talon i put the drift kit on but it took alot of mods to get it to fit just right because it made for the 92-94. the sides fit good but the rear and front are the problem. the grill coms mounted on the bumper all one piece so i had to cut it off and i molded the 1ga grill in its place the rear isnt quite mounted as of yet but i had to make brackets and new mounting points on both front and rear for a clean fit. i molded the side skirts and im going to mold the rear aswell soon as its mounted. i could post pix this weekend it you want to take a lookwith the front and sides on.
Where did you order/buy the drift kit from? The only place I can find is in Canada.. haha... PM me if you can
Then the rear was not made right from the start. The 92-94 body kit rear bumper will bolt right too any 90-91 eclipse talon or laser.
As for the front, you either have to convert to 92-94 headlights/marker lights, hood, and fenders, cut and mold your bumper, or find a 90-91 front.
Be careful who you listen to on here, there are tons of false things in 1g body kit threads. Most of which I correct when I get there.
The gallery here on tuners, if you select to view only 1gs, you will come across quite a few with kits.
QUOTE]
the bumper didnt mount as flush as i would like it thats why i am making new brakets. its fiberglass nothing fiberglass "bolts" right to anything some minor or in some cases major tweaking is almost always bound to happen. unless you get the first kit out of the mold or urathane(which has problems sometimes also) then it wont bolt right up no matter the kit or the car.
ill post pix of mine this weekend. www.extremedimensions.com is where i got mine
