my original idea =D
jay-d
175
Aug 11, 2002
Toronto,
I'm always looking for ideas that haven't been done before.. a couple I came across was.. the bass light inside the vent.. if any of you want to try this.. its pretty simple.. u have to modify the vent a little and the light itself.. gotta cut off a little of the edges, and for the vent.. at the back i just cut out little squares and silconed the light into the vent.. and put it all together.. the wire runs behind the hvac, is powered to the cigarette lighter and i bought a flip switch from home depot and replaced the empty space above the foglight with the flip switch. The 2 foot neon lights are also wired to the switch. Now the controller that controls the bass light is underneath eht steering wheel.. i have tilt so when u move the steering wheel up u can get 2 fingers in there and thats were the controller is.. all hidden and outta the way =D
Another picture here is.. a switch that turns my amp on and off.. cus i don't always like to listen to bass.. sometimes just want soft quiet music when cruising and instead of reaching to minimize it on the head unit.. a switch is a lot easier. The switch is wired to the remote wire for the amp.. thats all.. from the back of the head unit to the switch to the amp. =P
