dremersvision
- 289
- Jun 18, 2004
boring a$$ canton,
Ohio
I purchased a kenwood headunit from someone for a real good price. Installed it using the wire harness and it works perfectly but as soon as I go to put the volume up the head unit throws a "code off" sign on the display and shuts down... So I look on here and see that a good thing to do is bypass the stock amp. Ok but how do I go about this can I
1) just not connect the amp wires on the wire harness or
2) run new speaker wires to each speaker and then to the wireharness or is there another way which would make my life easier?
Do any of you believe that its the factory amp that's causing the headunit to shut down?
