Hiding stuff in 1g...TT, SAFC ect...
95blackGsTurbo
DSM Wiseman
5,023
81
Aug 10, 2003
Algona, Iowa
Im going to get getting a 91 Tsi AWD next weekend and I plan on getting a TT and SAFCII and such but does anyone have creative places for hiding these. I saw one car in the galary with the Blitz TT I believe in the ashtray place. Kinda have a crime problem around here and I wanna hide everything. Who's got pictures of there hiding places.
I put my turbo timer in the coin holder. Its the rectangular holder in the upper right side of the shifter console. You have to do some trimming of the plastic under the coin holder to make it fit, but very worth it. With the door to the coin holder closed you can't see it and you can hear just a faint beeping while its counting down. For the SAFC II you could also put it in the center console under your arm rest. I also saw something that put gauges in the center vent, but you could put the center vent back in so the gauges would disappear. The gauges were set pretty far back in the center vent. I'm sure you could do the same with the SAFC. Hope that helps some.
I mounted My turbo timer in the little peice of trim plastic between the dash and the center console (right under the radio) its at a slight upward angle, so its asy to read, out side people can't see it when your driving, and when the cars off, you can't see it through the window (mine are tinted tho, but ony 20%)
As far as the SAFC, I mounted mine in the driver side sun visor. its easy to do, but you have to have the dash out to route the wiring. I have it on the "up" side, so when the visor is up, you don't see it at all, pull it down to reveal it. very stealth.
im putting my boost controller switch in my ashtray compartment.
