1g altezzas
badas93tsi
495
Oct 17, 2002
Augusta, West Virginia
Does anybody know if 1g Talon tail lights are the same as the Laser, and Eclipse?
Yes they are all the same. The only difference is the Laser lights have a black strip at the bottom, the Talon lights have a refelctive strip at teh bottom, and the Eclipse lights usually have a painted strip through the center. The 90-91 are the same and the 92-94 are the same.
thats what I thought. thanks for the info man
actually the 90-91 are all the same except for the following. The Talon lights have a black strip on the bottom. The lasers have a reflective strip with the chrysler symbol embeded into the center piece. and the eclipse i believe have a stip across the center of all the lights that is the same color as the car. I am not sure about the 92-94 but if i remember correctly the talons are different then the eclipse and lasers because of where the license plate for the back is located.
Tried to get them to sell me only the side pieces and the ba$tards wouldnt do it. Oh well, STOCK RULES
i broke my drivers side tail light cover (90 mitsu eclipse GS)....they sold me the piece off of a talon....it had a white strip through the middle....i hooked it up with some tape....spray painted it the same color as my car....never tell the diffirence..but the junkyard charged me $70 for the light assembly.
So.............Black93TSi what you are saying is if you have a 92-94 Talon than you could buy the 1G Altezza Tailights for $249.00 and you can use the two corner lights,but you cannot use the center section???
If this is the case.... I was going to get the whole kit and only use the two corners anyway. All I need to know is that they will definitely fit??
