side skirt problem
95eclipseRsss
Jun 6, 2004
riceville, Tennessee
I have been trying to find out how in the world do u install side skirts :confused: . Ive looked and looked and i cant find out how its driving me nuts. How do u put them on.
It's pretty simple you have the plastic pieces that clip into the actual body then there are bolts/screws on the underside of the side. I believe one for each door cap and maybe 3-4 along the body of the skirt....put on the center piece first (I would screw/bolt that in first then push push in the plastic pieces onto the body) then finish with the door caps... VOILA! :thumb:
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
