Removing the Corner lights on a 91... please help
Open the hood and look down in the fender area where the lights are located. There should be 1 screw holding them in place. You take the screw out and the light will slide forward and out ;)
They should be straight down towards the front of the corner light in the fender. I don't have pop up's so they may block the view of the screw. Try putting them up and see if that reveals the location.
I tried removing the head light and all of the surrounding black plastic supports and still couldn't find any screw that was obviously holding the corners in place. I'm going to try again tomorrow. I have a feeling that its much harder with the pop up lights. Thanks for your help anyways.
take out the 2 screws that hold on the light under the pop up, where your blinker is, and after you take that off, you will see 2 more screws that hold on the corner light, take them out and slide it out. NOTE: you do not have to take the pop up light out, it should take you 5 minutes to do
Dude, If its a 91'...Pop the hood, and also your headlights and take the center peice "grill peice" out...only a couple screws, then take the blinkers off....youll see the screws, then youll see 2 small screws on a 90 degree angle holding the front of the corner lights, that was hidden by the bliker and then once the screws are out..you can pull them off.
-simple.
  • Wanted 4G63 800cc injectors
    • DSM_Thorpe
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
