Shift Knob for Laser RS
Famousgunner
39
Sep 13, 2002
I've trying to find a shift knob for my car. My car is a 90 Laser RS, automatic, and the problem is that my original shift knob has a O/D button, so I don't know if I regular automatic shift knobs will fit. Also can somebody please tell me how to remove the shift knob. Thanks.
Put your key in the ignition, then turn the car to the on position, not so it starts, just so you can put the shifter into L1. There is a phillips head screw in the front of the shifter, take that screw out. Then pull that cover piece off. Next there is 2 more screws inside. One that holds the O/D button in place, and one that holds the shifter to the pole. You will have to cut your O/D button wires in order to slide the old knob off the pole. Then you will need to rewitre the switch somewhere else inside your car with a new button or use the same button. Then you are all done.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
