5 X 114.3 rims
mtchll50
94
Jan 5, 2004
crystal river, Florida
sorry to put another question on a diffrent post but i wasnt thinking when i put the first one on but would a 5 X 114.3 245/45/18 rear and 225/45/18 front fit on a 1st gen Fwd eclipse. i am looking at some 350Z trck wheels if that helps answer the question easier thanks a lot
i ddin't think they would but i figured i would ask thanks for the help i guess i will have to keep me search going for wheels.
In my experience, you can get 245/35/18 with a +35mm to fit, but visually they stick out just a bit. With rolled fender lips they will tuck in under compression, though. There was at least a centimeter between the tire and rear knuckle, so I suspect you go with a slightly higher offset enough to get the tire to look flush with the fender and not look like it's stick out... of course I didn't take exact measurements :) Hope that helps.
