View Single Post
Old 03-03-2004, 11:57 PM   #4 (permalink)
GTM
DSM Wiseman
Region: SoCal
Classifieds Rating: (0)
Re: Valves dented pistons are pistons shot??
Quote:
Originally posted by 2K2Civic
The guy said just dremel it down and it should be fine. What is the input on this will it make the car run worse or bad?Justin
I much prefer to use a small ball-peen hammer and work the raised portion back into the dented area.
Use a wire brush on a drill motor so you can see your progress and knock off any sharp edges. Depending on the damage 5-10 min each piston, use lite blows, your not trying to bash anything or drive a nail in wood.
This way you don't remove anything, you don't change the balance and you have essentially forged the aluminum back into place by peening. You don't want any sharp edges for you can get hot spots which can cause pinging.
Cheers,
GTM
Offline
[posts] Reply With Quote
