How much nitrous can stock internals handle?
Patryk
368
Dec 29, 2002
Carol Stream, IL,
What would be a safe shot if im running stock internals, stock turbo (15psi), stock fuel injectors, stock fuel pump
Originally posted by rdrkt
I wouldnt run a wet kit on the stock fuel pump end of story. You can get a Walbro 255hp for like 100 bucks.
ok lets say i get the 255, how much can i run then?
Running a wet kit on a stock fuel pump is fine. Max shot I'd say would be a 75 shot. I'm running a 75 on a stock pump. But, since you're PSi is at what? 18? I'd recommended a pump upgrade, just due to the fact that you're at a higher boost level than stock, and by running a wet kit off of your fuel line could hinder your fuel/air ratio mixtures for the higher boost levels.
