Lightened flywheel questions
Turbo Monk3y
571
7
Oct 14, 2002
Orlando, Florida
Well i Finally have My Act 2600 and an EXedy lightened racing flywheel which weighs 12lbs. My question is (since many of you have already had experience with 2600s mated to lightened flywheels) Would the 2600 be a good match with the Exedy lightened flywheel and what would i have to do to make it last a while. Meaning Step height and that matter. the flywheel and clutch are brand new so the friction surfaces are nice and shiny never been used... The exedy flywheel is a Chromoly Steel wheel if that helps/ its Not aluminum retails for 500. Any suggestions/experience with these is greatly apprieciated. thanks:confused:
Don't overheat the flywheel and you should be fine.
