View Single Post
Old 10-01-2003, 08:53 AM   #4 (permalink)
Mike 99GSX
Proven Member
Classifieds Rating: (0)
Reputation: Mike 99GSX is an unknown
I'd say you're in pretty good shape. I would start turning up the boost now and continue to watch the timing and knock. You've got plenty of room with injector obviously since you're only maxing 58%. You'll probably see your timing drop down from the mid 20s as you turn up the boost but you should still be able to get near 20 at the top of 3rd at around 18-29 PSI on good pump gas.
____________________________
-Mike
Offline
Sponsored Links
