A larger flapper will help, but if you dont open the wg passage to let the air go through faster, theres no point. Before you do anything, take a hard look at your turbine housing and see where the air is going to go through the wg passage. Even if you get a huge flapper, its still going to be hitting the wg hole wall either way.
