Power steering Belt
Wickedinterface
Jun 25, 2003
Anyone here ever have a problem where the PS belt keeps comming off. Belt is tight to factory specs and it has slipt off twice today?
Check your Crank pully. If there is "ANY" play in it, replace it. that is the only thing i can think of that would pop the PS belt off
the crank pully. the crank pully, as also called the Harmonic Balancer has a rubber peice in the middle. This rubber peice has been known for seperating, which will cuase belts to jump off. Chech the Pully, if it has any play, replace it.
