Cut your main wiring harness open between the 2 mounts on the firewall look in there for a set of wires that go 4 into 1. Cut the splice out and wire the white or red wire from the res. pack the the white or red wire from your harness then wire the black wires from the harness to the black wires from the res. pack. Solder the connections and heat shrink them. then tape up the wiring harness and your good to go.
