Wideband wiring for AEM EMS
na_turbotalon
180
Jan 27, 2005
Edmonton,
I'm in the middle of looking through the AEM forums, thought maybe somebody here might have already done this. I need to know where I would tap the wires for the wideband into the EMS so I can work with the numbers on the EMS and read the values on my Serial gauge rather than putting in a seperate AF gauge. Thanks for the help.
Are you just wanting to run the analog output from your wideband into the ems?
I have the sensor from the AEM Wideband, I was hoping that there is a way to wire it straight to the EMS, then use the serial port and serial gauge to get readings. I don't want to have to put another gauge in my car. I don't know how to explain it that well, but I figure there must be somewhere to tap the wires from the sensor into the harness, or pins on the EMS, I'm just hoping someone knows which ones.
Pin 76 on a 2g is O2#1 for the AEM EMS, if you want the ems to be able to monitor your wideband that's where you would attach the wire.
You are going to need the controll unit not just the sensor. If you don't have it, it won't work.
Is the control unit built into the gauge? Or can I purchase it seperately and hide it away somewhere.
I have an AEM Serial gauge that can display the wideband information along with some other sensor readings, I have an AEM EMS, and I have the sensor for an AEM UEGO. I was hoping that I wouldn't have to buy the complete UEGO setup, since I have no use for the gauge.
That's what I have on my car. The best part is that it can be all tucked away so it can't be seen.
