Devils own-water injection kit--Hows it look to YOU?
Kit looks good to me. Looks pretty much like my homemade kit. The only thing i would advise getting (not neccessary) is a solenoid instead of the check valve. I personally dont have either since my pump is 4 inches away from the tb elbow and doesn't siphon because i am tapped off the stock windshield washer tank.
And just incase anyone chimes in, i have been running this for months with no issues.
Ok guys, I think Im going to pick it up..but some questions first. They list I need to pick a nozzel size...
all my mods are up to date, so what would you tell him for That?
Ill list
1 nozzel at throttle body, because Im front mount intercooled.
1997cc
2.0L
Front mount intercooled
Turbo
But what about EST HP? Im on 14B at about 18-19 lbs I was thinking of giving a 210-285WHP range, because I think thats what the 2nd stage is good for.
Im really excited about getting this, having my motor burn cooler, practically steam cleaning my motorand just allow for no knock. I dont kow why people dont make this a manditory mod....anyway Ill post results with a log before and after if peopl would like to know..
Also Does someone want to point me in the directing for a replacment soleniod for that check valve...and how is that actuated through an electrical sorce? Thanks
Alright I got off the phone with chance at devils own ( Irony, I know ) and after giving him my specifications his est was I would need a 3gph nozzle...he also explained that that was alittle ( verylittle bit ) big, but they dont come in 1/2 sizes....ant wont cause a problem
Heres my question to the folks who are full of knowledge....
Should I opt for the 2gph and just make up the difference wiht fuel or run the 3gph and be done. lastly
The devils own is a 150 psi pump and the kit is 175
I can get the base kit from coolingmist.com for 224 with a tank,but its only a 100 psi pump
http://www.coolingmist.com/pagedisplay.aspx?feature_key=Turbo_kits
Thanks for the input.
sbcxtreme said:
tried enginerunup.com? GREAT customer service. easy to follow dirctions also. very quick with replies.
I have but they seem to be higher prices, but also more advanced kits in a HP kind of way.
My next 2 mods are 1G TB, going on tomorrow and a water injection kit, what ever I go with here.
If I absolutly cant get the cooling mist kit stated above for 199 then I think Ill try to work some thing out wiht each vendor...both have had great customer service. Also what I like about the devils own kit is they have a forum dedicated to their kits and what not.
I have been searching and have decided to go with a checkvalve, and not solenoid....cooling mist informed me that the main part that was replaced under warranty was the solenoid...they failed...alot. They have a 0% failure rate on their check valves.
What nozzle are you guys running on your 14b, at say about 18lbs? Thanks guys.
