Quote:
Originally Posted by junseth
I dont have the harness or the ecu, all I have is the block. I think it would be a LOT easier to use the existing harness. What do you think is bad about ising the harness?
I am going to stick with the auto for now, as it still works and my gf can drive it. WHEN, not if, it breaks i will change it then. I am used to pulling transmissions lol.
So, the tranny will bolt right up to this block right? Am i reading this correct?
it should.. hmm..the starter should work too. just use your starter etc.
