sorry about the confusion as well, apparently there still isn't a way to convey sarcasm/non-sarcasm well across the internet.
and stingray 90, you are right, and that's what i was mentioning above. you don't ground those two wires. one from each solenoid goes to the ecu to be grounded, and the other from each solenoid has to draw power from somewhere (that's ultimately up to you).
where are you guys getting the idea that you should ground all those wires, did i mess up the write up somehow or was it somewhere else you saw it. if you could find it for me i'll make sure to correct it.
____________________________
-Kyle Mavis
#97 Street Modified Fort Wayne SCCA
