DSM gurus please help! Questions:
KenshinXero
Nov 30, 2003
1) If I put a 14b turbo in my 93GS auto tranny, how much gain am I expecting? If it is different with a 5spd, how much am I losing?
2) How much can I push the 14b using my non turbo engine?
3) If I install the turbo, do I have to remove the AC?
4) If i go to a junk yard and buy the parts for the conversion, how do I check for "shaft play" and other things I tend to hear online to make sure I get good parts?
5) I'm going to do the compression test and leak down test this weekend, how do I check if the "axles have exessive play" on them?
6) Sometimes when I brake really fast my car tends to be about to turn off and has in some cases, though this happens maybe once every 2 weeks or even once a month, this also happens when Im going to accelerate from a dead stop (less often than the braking).
Thanks a lot in advance!
-Ken
