1g 4g63 t ecu 2 n/t 4g63?
1g4g63gs2gst
Oct 20, 2003
will these parts transfer from a turbo to a n/t 4g63: fule pump, injectors, regulator, head, pistons, rods, and ecu. im sure all will exept the ecu. will be doing the work my self and would like to know if a amature mechanic could swap an ecu and how would i do it
the turbo ecu has 3 more connections(look at the vfaq, don't have the address off hand). the heads on a nt and t are the same, so no need to swap them, but the cams are different in a manual t. rods are the same, but pistons are lower compression, and are better suited for boosted applications(better designed for boost) you will also need the mas and the injector coilpack as well as the boost control solenoid.
i have been planning to turbo my car for a while now, and have done lots of research.....you should do the same. there is plenty of info on the conversion.
actually its the injector resistor pack, not injector coil pack. but that's cool, easy to confuse.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
