- 1,547
- 16
- Jun 28, 2002
Aurora,
ON, Canada
Today was the worst day of my turbo life. I was sick of leaking at 9psi, so I did an intake leak test. Found my leaks and fixed them.
Got into my car, pull on to the main road but I couldn't haul past 5psi.
It wasn't like I hit 5psi fast and then leaked. It was at 3k rpm, I was at 3psi, 4k rpm, I was at 4psi and at 5k rpm, I was at 6psi.
Reason - had a PCV valve holding back boost vacuum pressure to the wastegate. I don't understand how it works and by what I've learned, I shoulda been spiking just like I had no vacuum lines hooked up at all. Max boost. Instead, I was gradually gaining up to 6 psi up to 5000rpms.
I had the wastegate/BOV vacuum line hooked up to the PCV valve line coming from the intake manifold. I didn't realize that the PCV restricts air flow to the turbo vacuum.
LESSON LEARNED - If doing a turbo conversion and you want to hold 6psi and no more for cheap. Hook up a PCV valve in between your wastegate/BOV vacuum line going into your intake manifold.
It wasn't like I hit 5psi fast and then leaked. It was at 3k rpm, I was at 3psi, 4k rpm, I was at 4psi and at 5k rpm, I was at 6psi.Reason - had a PCV valve holding back boost vacuum pressure to the wastegate. I don't understand how it works and by what I've learned, I shoulda been spiking just like I had no vacuum lines hooked up at all. Max boost. Instead, I was gradually gaining up to 6 psi up to 5000rpms.
. I'd go with the ACT 2100lb clutch kit for the non-turbo tranny. It's not called the 2100 but it's the equivalent.
