SilverEclipseT
- 209
- Mar 7, 2003
Allentown,
Pennsylvania
I seem to have a problem with how fast my car reacts to fuel when the turbo spools up. I would like to know what you guys think.
It seems that if i accelerate slowly into boost i have no problems. however the quicker i try to accelerate in the gears it may take almost all the way through the gear for the fuel amount to catch up needed. Or when i shift gears then the next gear will not feel like it isnt robbed of fuel. I can verifiy with my F/A ratio gauge that it will run lean then shot to rich half way through a gear or after i shift.
My fuel pressure is ok it always seems to folow the boost levels, but i still have doubts about hahns FPR
So what should i do get fuel injectors (what size i plan on getting a howell bottom end and run about 18psi)
Or a FPR
Currently running 8psi
Thanks
Or a FPR
Thanks
