Aikouka
- 570
- May 30, 2003
Endicott,
New York
I'm pretty much ready to reassemble the head from my turbo engine and build it on the NA block. The only thing is, I was discussing with a friend about the differences between the two. The most notable being the compression ratios. The NA has a higher compression ratio. So my friend recommended I get the turbo pistons because the extra compression could cause problems, especially with the turbocharger providing more air to be compressed more than normal.
Should I buy turbo pistons to replace the higher compression NA pistons? Also, you do need different connecting rods, correct, or are the rods universal between the two?
Thanks for your help.
), and I was wondering whether you machined your block to include the oil squirters (or get a turbo block) or just ignore them?
