420a turbo VORTECH FMU question.....
99 gst 420a dsm
509
2
Jan 22, 2003
Turboville, New York
i have howell bottom end and all that jazz, putting out horsepower in the low 300's, which chip should i use with the votrech fmu? 12:1, 11:1? ect ect, i need to know asap if you can help, thanx!!!!!!!!!!!
im going to get the smc to run 450 or 550 dsm injectors, i herd to run the fmu and a safc
Don't use the DSM injectors, they are not the right type. Just buy some new injectors in the bigger flavor. You can pick up accell 44lb injec. from summit for like 30 a piece I think. You might need the SAFC for fine tuning later on. You have to decide what size injectors you will use before you chose a rise rate for your FMU. I would go to www.2gnt.com and search for Corbin's fuel pages to get a better idea of what to run.
well with civics, and other honda motors, alot of people use a smc and dsm injectors, its the smc that makes the injectors work right
