N/a engine to turbo engine help!
tsiawdeagle
Mar 11, 2003
:confused: how is everyone in dsm land.. i have a quick question. this guy will sell me a 1g talon with a shot engine, its seaized really bad, and he assures me its just the engine tahts f-ed up. the quesiton is, hes giving me a stcok turbo 1g engine and ecu, and i was wondering how hard would the install be, i have a shop to use (father inlaw) and all the tools as well, do i need anything else besides intercooler, im hnot sure if it comes with turbo piping and stuf, im pretty sure i does though, and how hard can it be to rout it... will the tranny match, can it handle the hp? if anyone has a complete step by step install guide it would be greatly appreiciated... thanks a lot guys, a newbie in need
ok, you mean your getting a NT car with a siezed motor and a turbo motor with harness and ECU to put in it? you need the harness first off, or at least sensors you can splice into the NT harness, injector resistor pack, intercooler and piping, but otherwise it will bolt right up to the tranny, however you should get a better clutch for the NT tranny or it will break fairly soon if you race it, so when your replacing the engine, replace the clutch and you should be fine
