ThumperSS
- 47
- Oct 20, 2002
Background. I plan on turboin my n/t but not til a rebuild is done. ive been checkin into howell and their bottom end kits. i don't plan on installing this myself. I'm having a shop do it.
1. i've called like 4 shop and they tell me they can't give me a warr. if i use other parts but their own. does howell give a warr. regarding their products or do i have to wish for the best and hope nothing gets messed up.
2. i plan on getting the 8.6 piston w/20 bore size. could someone explain what bore size is. i know that when you bore a part, your taking a bit off the sides to make it new. but does the 8.6 w/20 boresize mean the piston is going to be made wider to fit?
3. what sizes should i get for the main, rod and rod bearing?they give you options.
thanks for your answers.
