Bd1000Eclipse
Banned Member
- 756
- Nov 3, 2002
i'll be ordering my HRC stage one kit and i've been studing the install directions and i have everything down except for the fuel system confuses me a bit and was hoping you guys could help me
The HRC fuel pump is external right? What is it's purpose then if u already use the stock pump? just an extra precaution?
So does it just go inbetween the stock fuel line going to the engine? where exactly does it mount?
On the FPR the directions say to find the hose on the end of the fuel rail which connects the center fittin on the rail to the steel line on the firewall. Is this the rubber hose on the end of the fuel rail that i t'd off for my NX wet kit? So do you run a line where this hose used to go to the FPR and then a hose from there to the rail?
