Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Turbo Conversion
420A Turbo Conversion Turbo kits, swaps, etc - specific to 2G N/T DSMs.
Reply
LinkBack Thread Tools
Old 02-17-2003, 06:35 PM   #1 (permalink)
Proven Member
Region: Southwest
Classifieds Rating: (0)
Reputation: daltah isn't as helpful as most
everyone that has gone turbo how much hp do you have now
how much do you have know and how much did you have before going turbo?how much hp at the wheels and the crank
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Old 02-17-2003, 07:10 PM   #2 (permalink)
Proven Member
Reputation: siueclipse is more helpful than not
had 140hp at the crank, which is about 120 to the wheels...
now i have about 250hp at the wheels
hahn stage 2 + fmic
310cc injectors
Offline
Old 02-17-2003, 08:07 PM   #3 (permalink)
Proven Member
Region: Southwest
what are all the mods you have done?
Offline
Old 02-17-2003, 10:57 PM   #4 (permalink)
DSMtuners N/T Wiseman
Reputation: 98Turbbo420A is an unknown
Dyno'd 247whp Star Stage 2
Offline
Old 02-17-2003, 11:26 PM   #5 (permalink)
Proven Member
Quote:
i dyno'ed 218 with stock injectors and stock exhaust. the bigger injectors have helped a ton, and when the exhaust gets on that should help even more. so i estimate about 250 or so
Offline
Old 02-18-2003, 08:54 AM   #6 (permalink)
mavisky's Avatar
Region: Midwest
i would estimate around 150 hp at the flywheel nt, now i'd estimate 275-300 depending on boost.
here's the power mods.
Engine-90 tsi awd engine w/ 92 filter housing,tb, coil pack, and cam sensor
K&N filter
Ported big 16g
Ported 1g o2 housing
Vizzion Power Systems 2 1/2" intake pipe
Vizzion Power Systems mbc @ 19psi
Custom 2 1/2" upper intercooler pipe
1g nt throttle body rebuilt and powdercoated
HKS super sequential blow-off valve vented to atmosphere (flame on )
Accel 300+ Thundersport wires
NGK 7es's
Buschur 2 1/2 downpipe
Buschur 2 1/2 test pipe
Pacesetter 2 1/2 catback w/ 5" tip
3000 GT VR-4 fuel pump
Captain Clutch 5 puck disk with high pressure plate
Phantom Grip limited slip insert
Removed A/C and everything associated with it
Autometer pro comp boost
Autometer pro comp electric oil pressure
Autometer sport comp egt guage w/ tre k-type probe
Carbon Trix 3 guage pod
S-afc
it ran a 14.02 @ 104.7 on only 16 psi of boost and a huge pre-turbo leak that meant i didn't get full boost til over 5500 rpm.
____________________________
-Kyle Mavis
#97 Street Modified Fort Wayne SCCA
Offline
[webpage] [posts] [gallery] [blogs] Reply With Quote
Old 02-18-2003, 09:10 AM   #7 (permalink)
Proven Member
Region: Gulf Coast
Reputation: brynden29 is an unknown
I just dynoed last weekend and put down 285 to the wheels. And that was with a slipping clutch. Here is a list of my mods...
http://www.boosted-rs.com/images/completemodlist.jpg
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.14074397 seconds (73.22% PHP - 26.78% MySQL) with 9 queries
