Question on Purchasing a HRC Turbo stage 2 W/FMIC
ECLIPSE95
430
Nov 13, 2002
Missoula, Montana
I want to get a HRC stage II turbo for my 95 Eclipse RS w/ a FMIC I went to there site and I will be ready to order this summer but I don't know which one i am suppose to get for my elcipse there are two Item numbers....
Item ID
Description for Sales
H TS-2102
Turbosystem, Stage 2, 95-99 Talon and Eclipse, 420A engine, 8/94 to 12/95
H TS-2202
Turbosystem, Stage 2, 95-99 Talon and Eclipse, 420A Engine, 1/96 to Present
H TS-2402
Turbosystem, Stage 2, 95-99 Neon, 420A Engine, 8/94 to 12/95
H TS-2452
Turbosystem, Stage 2, 95-99 Neon, 420A Engine, 1/96 to Present
AFTER 420A ENGINE FOR ECLIPSES ON THE DESCRIPTIONS IT SAYS 8/94 TO 12/95 AND THE OTHER SAYS 1/96 TO PRESENT WHAT DOES THESE NUMBERS MEAN? THANKZ
Those numbers are for the manufacture date of your car. Hahn will ask you or you should tell them because the "early" Eclipses had a slightly different fuel system. It is very important that you let HRC know when your car was manufactured. I think that it should be listed on one of the stickers in your drivers side door jam.
Most likely it will be the first date that you listed on your post, but check to make sure.
Good luck.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
