Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Turbo Conversion
420A Turbo Conversion Turbo kits, swaps, etc - specific to 2G N/T DSMs.
Reply
LinkBack Thread Tools
Old 05-03-2008, 10:49 AM   #1 (permalink)
Proven Member
boostnhard's Avatar
Region: Southeast
Classifieds Rating: (0)
Reputation: boostnhard is an unknown
420-a not starting
ok here is the problem.
my friend has a 97 rs that used to run like a new car( i mean perfect)
We decide to turbo it, but before that we wanted to get the head rebuilt beacuse ithad bad valve seals. So we get the head back from the machine shop,put it back, torq it, set the timing on the car, crank it up and it wonk start.
The crank and camshaft pos sensors have both been replaced, same as the ECU.
Theres no spark, there gas but no spark. Its all i need, and ive tried everything i can but cant get the damn spark
Any help is greatlt apprecciated
____________________________
Angelo-Evo lll
Online
Related 420A Auctions
Old 05-03-2008, 11:01 AM   #2 (permalink)
Proven Member
Ajax's Avatar
Region: Midwest
Reputation: Ajax is an unknown
Have you guys changed camshafts? Check the magnet on the camshaft.
Offline
Old 05-03-2008, 08:35 PM   #3 (permalink)
N/T DSM Wiseman
Locke's Avatar
Region: Midwest
Check that you didn't accidentally swap the VSS and coilpack plugs.
-Locke
'99 OZ Eclipse
Online
[posts] [gallery] [blogs] Reply With Quote
Old 05-04-2008, 09:34 PM   #4 (permalink)
Proven Member
boostnhard's Avatar
Region: Southeast
the camshaft are the sameas before.
LOCKE maybe is right, i will double check on that. it is a possibility. thanx
Angelo-Evo lll
Online
Old 05-13-2008, 01:41 PM   #5 (permalink)
Proven Member
boostnhard's Avatar
Region: Southeast
nope not inverted! so what else can it be?
Angelo-Evo lll
Online
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
AWD with a 420 is it possible... Davion1089 420A Bolt-on Tech 4 09-26-2006 09:52 AM
420 rebuild cost? DJ NME Newbie Forum 1 05-19-2005 06:09 AM
420 timing TRUSTEDONE2003 420A Bolt-on Tech 8 04-21-2004 09:52 PM
420 or 4g63 brewer420A Problem Diagnosis 0 03-08-2004 07:33 PM
most you can do to a 2g 420 engine ProJek-S&G 420A Bolt-on Tech 10 09-19-2002 10:39 AM
Page generated in 0.11858201 seconds (67.12% PHP - 32.88% MySQL) with 10 queries
© 2001-2007 SPEEDtuners Network, LLC All Rights Reserved
We recommend the Firefox browser. Get
