Feedback line
Mitxubishi
45
Mar 9, 2005
La Grange, North Carolina
Hey just upgrading my new turbo and I came cross a lil problem. I was replacing my old feed line and Im having alot of trouble putting the new one in. Im prbly gonna have to remove the intake and few cables but was looking a for an easier way around LOL. Seeing if anyone has any suggestions. Thanxs... lata
Dude, I'm confused as to what you are asking.
Post a pic of your engine bay or set-up if possible.
If you are having trouble with the feed line just give it a little elbow grease. It's an oil line, so once you break it loose the oil (from within) will seep into the threads. It should come right off after that.
I still don't know what you are asking though. :confused:
Basically the position of the hole for the threads to line up, its unreachable. Im prbly gonna have to remove the intake to get a betta angle and postion on it. I was tryin to avoid that but I think its the only way. But question now is, how easy does the intake come off? Is it pretty straight forward or wot? Now goin bac to my first post, I said i already removed the old line that was thea with my old turbo. NOw I gotta screw bac the new one and call it a day. Hope I cleared up any misunderstandings. Let me know... thanxs
Yeah, getting back there sucks. I found the only way to do it (without removing the intake manifold) is to remove one of the brackets that holds the intake manifold up, then doing it from underneath the car. Jack the car up as high as possible to give yourself plenty of room. It's totally doable that way. Oh, and having an extra person around never hurts either.
By the way, since we're on the subject of turbo feed lines, does anyone have any problems with leaks?
I don't remember doing anything up top, just removing the Oil Pressure Sending Unit from underneath :confused:
None hear from what I can tell. ~2 years of operation
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
