zaebst
- 143
- Feb 19, 2003
Grand Rapids,
Michigan
ok well all i've technically got left before i can fire up the galant is a little wiring. but i can't figure out mainly how to run my maft on my n/t wiring harness. because the n/t harness has a 6 pin plug which from the looks of things is a little smaller making the maft not so plug and play (narrower). assuming i decided to try wiring in a turbo 1g plug, the white wire for my maft goes to an rpm signal which is ok, but the 7th wire is a purple wire that is not in the main plug and is not mentioned anywhere by anyone or in the instructions. can somebody maybe give me a clue here so i can atleast have this thing running by 4th of july weekend?
