how should my turbo position?
Blitzeclips
1,571
6
Aug 5, 2004
Bear, Delaware
hey guys, i just bought a garrett T25 BB turbo from a friend with under 2k on it. its in great conditon but it came off a 01 civic. the manifold i bought was for a 420a with a t25 flange on it. the problem i am having is that the turbo's flange wont line up correctly with the manifold. now the manifold was put together properly because the mounting position is almost exact to the hrc's. the problem is that the flange on the turbo is horizontal. whereas the flange on the manifold is the opposite. i figured i could have a friend cut and reweld the flange but even then my turbo tucks pretty far down by my manifold. the wastegate sits maybe 1 inch from the manifold too. can someone post pics of thier setup and help me out with my problem. i figured i could change the exhaust housing as it may not be correct for my car. but even then, what kind do i buy? a 2g gst housing? where can i buy it? havent found 1 yet. thanks for any help
Pictures are worth a thousand words, so give us some so we got a better idea of what you're dealing with :thumb: to help you out :dsm:
