BISS 420a
redeclipse7782
463
7
Oct 20, 2004
Worcester, Massachusetts
I have a star stage 2 turbo on my 97 gs 420a engine. I was wondering if there BISS screw on a 420a throttle body? My car idles at 1000-1200 rpm's and if i shift into neutral while driving my rpms go to 1500 and do not drop down. This also happens when i come to a stop then after a couple seconds slowly drops down to 1000-1200. If anyone has a picture of a 420a throttle body and where the BISS screw is it would be greatly appreciated.
Thanks,
Brian
NO. There is no BISS screw as there is on the 4g63. Our idle is determined by the ECU/PCM.
Try putting your foot under the gas pedal, and lifting up. It could be that you throttle cable is sticking. It has happened to me a couple times.
