Wiring for TT
Turtle
Sep 5, 2004
laramie, Wyoming
Is the wiring on the inside the same on 2G turbo and N/T? I'm looking to install my Greddy TT, but i'm not real sure about the alarm wiring. I found a write up on vfaq but it was for a turbo. so if it is the same thats awesome, if not then could someone maybe tell me what they taped for a greddy TT install?
yeah, i'm having the same proble,, i can't figure out where the green red and white wires go.i'm sure there for my alarm system, but i'm not really sure where that stuff is.
could someone please just tell me where the alarm wires go, i have the greddy tt optional wiring harness, could you tell me where each color goes, i don't really need to know where the wires are, just what ones to tap, please help this is gonna make me go crazzzzzy
did you figure it out?
Im in the same boat, trying to hunt down the wires to splice this timer in.
Let me talk to my tech guy this after noon, he wired my car up so that my AFTER MARKET DEI ALARM would still work even while my car was still running. He did what I wanted but I don't think my cruise control works now cause of it, but who needs it anyways. (just advising you). Also after I post an answer to this just remember not to leave your stereo blasting while the TT is going and your alarm is set. (it sets of the shock sensor especially if u have subs) I learned this after walking into a costco and having my alarm paging me every 3 secs.
I'll get back at you guys hopefully this afternoon, but he might not get in to the shop until 4pm PST.
It all seems pretty cut and dry cept for the tach wire. I was hoping someone knew what color it was offhand.
the ecu tach wire? its the white wire in the lower harness :thumb:
wookieneck said:
dont suppose you have a pic?
uhh no, but just undo some wire loom and look through the lower harness's wire bundle, its the plain white wire, not hard to find at all
Ive got it all wired as far as the standard features, that was simple. Its figuring out which wire is the speed sensor wire thats the trouble. Its in and it works but I have no clue which wire to use for all the bells and whistles features.
