possible injector swap??
turbowannabe
Jul 30, 2002
alright, my father jus bought my older brother a new car leaving the old p.o.s. 91 sonata rotting away in the drive way. for the last couple of weeks ive been snooping around the car and noticed that many, almost all the parts are exactly the same except this engine is a 2.4. i did a swap with my mas because i f-d up my old one up and my car ran BEAUTIFUL!!! now, my idea was since the sonata is 2.4 and im running a nt 2.0 the injectors in the hyundai must be bigger, right? the injectors would work in my laser, i know that for a fact... what i dont know is wheather i will be hepling or hurting performance and weather my ecu will be confused and create a mixture too rich. or should i invest some money and buy a s-afc, do the swap, and have it professionally tuned.does the rule of more fuel=more power apply here? help me i tearin my hair out!!!!!!!!!!!
I would recommend checking with some hyundai forums and see if someone can tell you what size they are so you would actually know. If that does not work you can always have them flow tested.
I would consider having them cleaned and balanced as old as they are anyway at the least.
