Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 420A DSM Tech > 420A Bolt-on Tech
420A Bolt-on Tech Intake, exhaust, ignition, fuel system, cooling, etc - specific to 2G N/T DSMs. New Members must limit their 420A tech posts to this forum.
Reply
LinkBack Thread Tools
Old 11-02-2003, 09:12 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: Laser93Nash is an unknown
1G-specific Cheap/Home made mods
I'm on a tight budget. Are there any cheap mods I could do to my car? Like making a CAI out of parts from home depot. I'd like to know how to do that. Anyone know what I need and how to do it?? Any other easy or cheap performance mods or tips would be appreciated.
~Andrew~
Offline
[posts] Reply With Quote
Related 420A Auctions
Sponsored Links
Old 11-03-2003, 01:13 AM   #2 (permalink)
Proven Member
Reputation: workin_on_it is an unknown
you could use plumbing piping(the plastic stuff) but i have heard that it gives off toxic gases from the heat of the engine bay...not sure how true that is..... and you could do a k&n and hack the air can and build a heat sheild(thats what ive done minus the piping) made a nice increase on the butt dyno....sounds way sweeter too...you can really hear the air getting sucked in......then headers and exhaust. i have a pacesetter header that i have wrapped in exhaust wrap, and a custom exhaust with no cat......hauls pretty nicely......not as nicely as when i go turbo tho....
i might also be selling my header soon since i am turboing it.....
Offline
Old 11-03-2003, 09:03 AM   #3 (permalink)
Proven Member
Drifte's Avatar
Region: Midwest
Classifieds Rating: (1)
Reputation: Drifte is an unknown
go to menards, thier are endless mods. If you want to replace random hoses with stainless covered ones, you can get those too. And they have plywood so you can make a really big wing.
____________________________
coltondk
Offline
Old 11-03-2003, 11:56 AM   #4 (permalink)
Proven Member
Reputation: Megags is an unknown
I took the resonator under the fender off and cut a square-shaped hole into it, cut off the "neck" off of the airbox. I attached the neck to the square shaped hole and mounted it so that it would go directly into the front bumper cutout to ram air into the airbox. Used the piping from the airbox as a forced air input. I sealed all the flaws in my cutting with 3m window weld. I should probably seal up the hole that was from the neck.
I know thats probably hard to follow.
Offline
Old 11-03-2003, 08:18 PM   #5 (permalink)
Proven Member
Lol. Plywood wing. Right. Only Honda guys do that. Stupid huge ass wings.
~Andrew~
Offline
Old 11-03-2003, 11:16 PM   #6 (permalink)
Proven Member
Reputation: dj_u4ea is an unknown
yeah you can take your "throtle body" off and go to a local machine shop, have them bore it out about as big as they can,then after resetting your iac,you should get a little push up there, cost about 20-25 dollars to do this yourself, also buy a dremel. take it apart and start porting out your intake and exhaust, that helps a little too...
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.12170506 seconds (74.61% PHP - 25.39% MySQL) with 9 queries
