will bigger injectors and ecu help?
From what I hear, you wont get any horsepower. You'd just run to thick of a air and fuel mixture. So I hear. I dunno. I'm still learning. Someone correct me if I'm wrong.
~Andrew~:laser:
Bigger Injectors with a turbo ecu would make your car run worse. You only upgrade to bigger injectors if your maxing out the duty cycle of your current injectors and they can't supply enough fuel. so unless your making enough power to use up all the fuel your injectors can supply, you don't need bigger injectors.
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
  • For sale 2g 2G DSM Link V3
    2G DSM Link V3 $595 + shipping and paypal fees* no cable includedYou must be registered to...
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
