Fuel Injector Swap
Skyeclipse
Jul 12, 2003
My buddy and i tried to swap out the stock injectors for some 350cc's but we couldn't get the fuel rail off and i didn't know if you guys had some tips for doin that......
Just rempve the 2 mounting bolts un hook the lines and it should pop right out. I want to tell you though that unless your turbo then that upgrade will do you no good and acctually may cause more problems. Why do you want larger injectors?
more fuel does not = more power unless you added a mod that requires more fuel. bigger injectors are good on turbos because more fuel delivery means you can turn boost higher without going lean but on a NT i dont see how that will help, if anything it will bog you down and make you run rich and worse
^^^^ exactly except the ECU should be able to lean them down enough to keep him from running too rich. The fact is the N/T's run rich from the factory so adding these will not help at all. Fuel and air together make power not one or the other. So if you increase air but not fuel or vice versa then it will hurt rather than help. If you add one you must add the other.
