2ndGen420A
- May 2, 2003
Got a new noise as of Saturday afternoon...hoping you guys can shed some light on this for me...
On my '95, I'm running the following:
Stock wheels/tires
Eibach Sportline springs
KYB adjustables
When I stab the brakes hard and for a brief moment, I hear a clank. Yes, just like that. Stab brakes, and then "CLANK". This sound is coming from the rear passenger side, and it occurs ONLY when I stab the brakes. Gradual braking does not produce this noise. I pulled the wheel, and started looking. I found the following things that COULD maybe cause the sound I'm hearing:
1. Caliper has lateral play. I loosened and then retorqued the caliper guide pin bolts...caliper play remains.
2. Upper control arm bushing is severely deteriorated. No excessive play noticed. Of course though, I am not physically capable of reproducing the force that my Eclipse can generate on this bushing.
3. Sway bar end link bushings have considerable play. I can move end link 2 1/2 inches with my index finger and thumb...
Any thoughts guys?? I'm thinking if I can't figure this out, I'm going to replace ALL bushings in the rear end with Energy Suspension parts and see if that doesn't fix this problem....
I can't really see the sway bar making this type of sound. Shock is still good, and tightened to specified torque rating. Could the play in the caliper be doing this? I still think that's a strong possibility...
Anybody who can help will be greatly appreciated!!
Stock wheels/tires
KYB adjustables
