Aftermarket Pulley Set
Thanks, but no I checked there too and there is not.
On a side note, I just had a friend check to see whats wrong with my pulleys (my alt & p/s belt flew off a week ago - BRAND NEW), and I was thinking the tensioner rod was not tightened right enough by the mechanic, ( maybe even stripped the bolt) as I could easily wiggle the bolt after we found out the belts came off. Put new belts in, tightned the bolt even more, but a week later noticed a rattling sound. So today were playing with the idle, and the coolant starts leaking out of the resevoir bottle and the engine heat spikes up. So now I'm thinking it could be a bad radiator or maybe I have a bad syncro problem in my clutch as to whats making that noise; my 1st gear has always grinded a bit from neutral.
P.S. if my Tranny is fubar'd , there are no aftermarket trannies like BM or TRE for 420a's? Cant find any...
